RazMan
| posted on 13/12/05 at 09:10 PM |
Flush fitting numberplate lamps?
I am looking for a flush fitting numberplate lamp (maybe a pair if appropriate)
It needs to go above a conventional UK plate in a horizontal surface.
Can anyone offer any pointers? I can't seem to find any with the usual suspects
Raz
dave dickson
| posted on 13/12/05 at 09:50 PM |
Have a word at your local caravan dealer.
The rear numberplate lamps on a Bailey Senator are rectangular things about 3 or 4 inches long and maybe 1 inch wide. They sit in the horizontal panel
above the recessed number plate, and sit proud of the suface by a few mm in a rubber seal.
RazMan
| posted on 13/12/05 at 10:17 PM |
Sounds ideal! I'll have a sculk around the local travellers site then
Raz
omega 24 v6
| posted on 13/12/05 at 10:24 PM |
V/hall astras carltons/omegas estates all have recessed light in the tailgate handle. I might even have a pair lying in the shed but it'llbe the
weekend before I can check/photo them for you. If I have a pair you can have them for the postage.
RazMan
| posted on 13/12/05 at 10:31 PM |
Jolly decent of you old chap!
Raz
andyps
| posted on 13/12/05 at 10:40 PM |
Rover 800 number plate lamps are flush fitting. Loads in scrap yards.
| posted on 14/12/05 at 10:54 AM |
I don't understand what you mean by a flush fitting lamp - is the number plate recessed? It has to be otherwsie if the lamp is flush and the
'plate is on the same surface, it cannot possibly be illumintated. Just curious.
RazMan
| posted on 14/12/05 at 12:31 PM |
Sorry about being so vague - the plate is indeed recessed and the lamp will be mounted in the recess 'wall' above the plate. So if the
lamp sticks out more than a few mm it will obscure the plate itself hence the need for flush mounting.
Raz
| posted on 14/12/05 at 01:52 PM |
ok; that makes sense. volvo 850 estate have two lamps in the rear tailgate handle that sine linght onto a recessed plate.
A trip to the local scarpyard should prove to be a good source - can't imagine there is much demand for such items.
tks
| posted on 15/12/05 at 09:34 PM |
i will be in for one item to..:D
Willing to pay for postage and some more if needed...
i have no idea what to do anyway with the license plate of the car...
anyway i need the item in the drawing if we need the same or someone has one laying arround i'm willing to buy it..
Tks
RazMan
| posted on 15/12/05 at 10:30 PM |
tks - By the look of your drawing you just need a classic surface mounted Lucas style lamp like
Raz
