Avoneer
posted on 2/1/06 at 02:06 PM |
Under dash to back of car???
Just trying to work out how many wires I need to go to the back of the car from under the dash.
I have a nicely rubber insulated 7 core cable which I want to utilize.
I think I can get away with 7 cables:
1 for rear lights +ve
1 for rear brakes +ve
2 for indicators +ve
1 for fog light +ve
1 for fuel pump +ve
1 for fuel tank sender +ve
All negatives will be wired together and earthed at the back of the car.
The number plate light runs off the rear lights so no cable needed there.
Am I missing anything???
Pat...
darrens
posted on 2/1/06 at 02:12 PM |
Take it your not fitting a reversing light?, I'm also pondering same thing......
Darren
Kev99
posted on 2/1/06 at 02:20 PM |
U Might Need Speedo Pick Up If Sensor Is At Back + Hand Brake Switch Is Down That Way
Avoneer
posted on 2/1/06 at 02:32 PM |
Using blade engine so no reverse.
Handbrake is vertical up against the dash.
Speedo sensor will be in the engine bay.
Anything else?
Pat...
Bob C
posted on 2/1/06 at 02:53 PM |
Damn - forgot the handbrake switch..........
I also have 2 rear sidelight wires - trailer wiring practice, I've not seen mandatory requirements anywhere
Bob
posted on 2/1/06 at 03:23 PM |
You don't have to have a handbrake warning light and it's not wired to the rear anyway. I'd run the fuel pump on a separate wire a
bit heavier than the lighting cable.
Avoneer
posted on 2/1/06 at 03:33 PM |
Still sticking with my 7 unless anyone else knows why not.
My rear lights were on one cable both on my Tiger supplied loom and on the Premier loom.
Pat...
dave r
posted on 2/1/06 at 04:52 PM |
no, but you have to be able to prove the fluid warning light works from the cockpit ??
posted on 2/1/06 at 05:16 PM |
So wire it to earth through a switch on the dash, old Minis use a rocker switch with a light in.
darrens
posted on 2/1/06 at 06:08 PM |
I would dito running the fuel pump in at least 1.5mm. If you really wanted to scrimp 0.75mm would just cover an average injection pump.
Darren
Avoneer
posted on 2/1/06 at 06:21 PM |
It's only a low pressure carb pump and cable is from an old tow bar so will be moer than up to the job.
Pat...
