chrisg
| posted on 2/1/06 at 03:19 PM |
Speedo options
I've changed my four speed gearbox for a five speed.
it's the later type without a cable drive.
I need to sort the speedo out.
As I see it I've got three options.
1 .a bycycle speedo.
2. A new electronic speedo with sensor
3. Adapt the Granada speedo to suit my dash, running off the original ford sender in the gearbox.
What do you think?
cheers
Chris
Edit:
I've just thought I'd like to build a digital dash, but as I struggle to wire a plug, this might not be a viable option!!!
[Edited on 2/1/06 by chrisg]
Avoneer
| posted on 2/1/06 at 03:34 PM |
Bike speedo - £10.
You can mount it right above the wheel in front of you as well.
Not lit for night though.
Pat...
lsdweb
| posted on 2/1/06 at 03:42 PM |
M&P used to do a holder. with lights, for push bike speedos for the custom bikers.
Have a search here
I remember seeing these in their catalogue a couple of years ago.
Wyn
Chippy
| posted on 2/1/06 at 11:30 PM |
I would recomend the KISS system, if you already have a serviceable speedo, and a virtualy bomb proof way of running it, why pay out for another, less
reliable one. IMHO. Ray.
chrisg
| posted on 3/1/06 at 04:40 PM |
Other than having no way of driving it It's perfect.
There is no cable drive on my gearbox.
Chris
Bob C
| posted on 3/1/06 at 05:21 PM |
you could always buy one of mine if you want. . . . . . . .
I'm making a small batch at the mo.
Bob
chrisg
| posted on 3/1/06 at 05:34 PM |
How much mate, bearing in mind that I'm a pensioner and poorer than a church mouse?
(And tight as a ducks ar5e)
Have I got anything you need, I like to barter.
(Flashes a bit of leg)
I could help your development programme, you know, testing and that.
Chris
flak monkey
| posted on 4/1/06 at 02:03 PM |
Hmm, looks rather neat Bob.
Any more info on it?
Sera
http://www.motosera.com
Bob C
| posted on 4/1/06 at 02:29 PM |
Here goes Dave -
the photo is a prototype without gear indicator, it was developed for a BEC so has super fast zero intertia revs display.
http://freespace.virgin.net/bob.carter/files/dashbunf.pdf
cheers
Bob
flak monkey
| posted on 4/1/06 at 02:56 PM |
Cheers Bob
Looks rather good! A very impressive array of features indeed!
Looks like most of the features would work with a car engine as well? Though obviously there would be some which were redundant.
The next question is of course, how much? And which transducers come with it?
Sera
Bob C
| posted on 4/1/06 at 04:56 PM |
Hi Dave,
at zero volume £200 means I don't actually lose money..... That gets the basic 2 PCB stack plus a LCD totaliser (& battery) odometer, the
speedo vane switch and some connector bits. In reasonable volume they'd only cost a quarter of that!
They work with any variable resistance oil pressure and fuel and temperature senders - a resistor can be swapped to improve linearity if required.
I have to do the gear display setup in the configuration (I have the data for R1 and ZX9R) so for CEC I'd leave the gear indicator off and alter
rpm display to a linear scale up to 9krpm
flak monkey
| posted on 4/1/06 at 08:48 PM |
Sounds pretty good
How many do you need to be able to do to get the price down? I am sure several people on here would love one for their car! Plus I cant stretch to
£200 at the moment anyway. Maybe in a year or so I could!
Sera
