darrens
posted on 6/1/06 at 12:55 PM |
SD1 Clutch
Just been to get a clutch for the project and as usual there are two variations, both the same size for the SD1 3.5ltr,
The gearbox I have is the LT77 17A, do I go for the earlier clutch for this box or the later type, would imagine the earlier one for this box but
don't want to order it and not be the right type.
Darren
posted on 6/1/06 at 01:45 PM |
is it a battery powered engine? just wondering why posted in this topic?
pbs
posted on 6/1/06 at 03:18 PM |
The differance between the two clutches depends on what type of thurst bearing carrier you have, plastic or metal as the thrust bearings and presure
plates are different.
I think you can use the clutch kit with the plastic bearing carrier on any engine/gearbox combination as the thrust bearing and carrier are one
piece.If you buy the clutch kit for the metal bearing carrier you need the thrust bearing carrier.
Have a look on the rimmers brothers web site www.rimmerbros.co.uk or give them a call as they can advise which one to buy.
The plastic bearing carrier is the later one
[Edited on 6/1/06 by pbs]
Build your own sports car for £250 my ar5e!!
darrens
posted on 6/1/06 at 04:59 PM |
balls......
sorry for posting in the wrong section
