joolsmi16
posted on 7/1/06 at 01:30 PM |
wiring route
Hi does wiring have to go through the transmission tunnel? thinking of routing my wiring along the passenger bottom rail?
RazMan
posted on 7/1/06 at 02:11 PM |
No reason why you can't go anywhere really. Just make sure you can access it for maintenance, make sure it is firmly secured with P clips or
similar, avoid any hot spots and it should be fine. Grommets are essential if you are going through metal panels or rails.
[Edited on 7-1-06 by RazMan]
Raz
oliwb
posted on 7/1/06 at 06:28 PM |
Do they look for grommets everywhere?? got a couple of places where wires go through ali sheeting without grommets.....they are secured very close in
both sides securely and I've heatshrinked them twice to protect, one has conduit sleeve stuff over it aswell.....will this be OK for SVA or
not??? Cheers Oli.
RazMan
posted on 7/1/06 at 06:50 PM |
If you have heatshrinked the cable entries I reckon you will be ok. I mentioned it more for safety than anything else - you don't want to risk a
fire due to a short
Raz
zetec
posted on 8/1/06 at 08:45 AM |
I routed cables along the top and fluids along the bottom, then if there is a leak the wiring is kept dry.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
