robertst
posted on 5/2/06 at 07:57 PM |
The stripping dilemma, inputs appreciated
Hi again:
well, i have already found my donor, a 1987 Sierra 2.0 GLX, for 200 quid!!!!!!! but thats not my dilemma.
after i buy the car i will need a place to store it while building the chassis and stripping it later. THats the dilemma. you see, i dont really have
an open garage or peaceful neighbours either. my garage is a shared one and in order for the dismantlers to come pick up the wreck after stripping
with their huge lorry with a huge crane to loft the wreck, the car will obviously need to be outside the garage. now, i have planned out a trial
procedure in order to plan the order in which i shall strip the car down so as to maximize my time in the garage and outside, whilst not bothering my
easily annoyable neighbours and/or having to tow the car with all the scraping and noise.
please, any comments will be appreciated:
So, inside the garage i plan to:
1.remove the engine, gearbox, radiator, etc, everything EXCEPT the drivetrain, steering column and brake system (i'll explain later)
2. remove wiring loom, electrics, etc.
and then i will need to tow the car out to the exterior parking lot (it's a private lot) hence the need for the wheels, steering and
brakes, and whatnot.
another difficulty is that this parking lot is on a gradient! so it will make removing the axles and wheels much more difficult. but i have another
procedure that could work.
1. by engaging the handbrake, and putting wheel studs to avoid the back wheels from even vibrating, i plan to jack the front up, put axle stands and
take care of the front.
2. then, using friction as an advantage, with no wheels or front axle for that matter, i will do the same thing, but for the rear axle.
about the neighbours, i guess i can cover the wreck with one of these car covers.
so, there you go... a very long and complicated procedure, but i guess it can be done if i can order the operations the best way as possible. thats
where you guys come in. any suggestions, extra procedures, safety, etc?
thanks!!!!
Avoneer
posted on 5/2/06 at 08:09 PM |
Do you mean a shared drive - not garage?
Anyhow, strip the shell completely in your garage and weld 4 cheap B&Q castors on the shell to roll it down the drive to the collecting truck!
Pat...
dave-69isit
posted on 5/2/06 at 08:13 PM |
striping cars
were are you baced
dave-69isit
posted on 5/2/06 at 08:14 PM |
based
robertst
posted on 5/2/06 at 08:42 PM |
umm... i'm in Madrid, and yes its a shared drive. but theres also a shared garage with 6 cars or so. B&Q?? wats that?
posted on 5/2/06 at 08:56 PM |
b&q is a hardware store found all over the UK
your plan is generally sound. However, the handbrake alone is sufficient for low speed manoevering, so you can remove the brakes inside too. Axle
stands arent necessary when removing wheels, just drop it onto the removed wheels! Take the nut off the top of the front struts before you jack it up.
For the back, remove the full subframe (6 bolts, shocks and cut the cables/pipes.)
omega 24 v6
posted on 5/2/06 at 09:04 PM |
OK so your in sunny SPain here's the plan.
Invite all your mates to a car stripping barbeque where you supply all the food and beer.
Hire a trailer and pick up the car in the morning and transport it home. Mate's arrive and strip the car in one day and store away all the
parts. All of you lift the shell back onto the trailer and take it to scrap merchant and drop off trailer. Home in time for tea (barbeque) and get
well bladdered in celebration. You could invite the neighbours to the barbie to too keep the peace.
Job done.
SixedUp
posted on 5/2/06 at 09:11 PM |
Been part of something close to this in action, and it works well. It's a formidable sight.
Most neighbours will cope with a single day of disruption, especially if warned well in advance and bribed with a bottle or two. Of course, if they
don't then you have all your mates with you to help back you up...!
Richard
zilspeed
posted on 5/2/06 at 10:24 PM |
Definitely agree with the above.
If you can get the neighbours onside beforehand you'll keep the peace.
I'll be having a concrete mixer (spotmix) outside my house in a couple of weeks. It'll only be there for around 40 minutes, but
it'll be early on a Saturday morning. I intend speaking to all the neighbours beforehand and making peace before we fall out.
I honestly think this is your best course of action.
ned
posted on 5/2/06 at 10:34 PM |
i didn't really think about the collection of the stripped donor when i did mine, ended up putting some old board/pallets on the drive and just
dragging it out with the everyday car. I needn't have worrried, the salvage truck winched it out of the narrow driveway onto the road anyway
before loading it on the back of the truck!
Ned.
beware, I've got yellow skin
Johnmor
posted on 5/2/06 at 10:52 PM |
For B&Q in Spain
see "Leroy Mervin"
dave_w11
posted on 5/2/06 at 10:53 PM |
I did the entire strip in the garage and then just put back the bare minimum of what was required to put the wheels back on to roll it out the garage
and down a downhill shared drive. There were 3 of us to stop it and we were going to put an old trailer behind for it to bump into just for incase it
tried to get away.
As it was it took 3 of us to get it to go down the hill. We took it backwards and with the steering rack not attached the wheels splayed out and acted
as brakes whenever we tried to push it so it wasn't going anywhere far of it's own accord.
The rest of the stripping (just taking the wheels and rear axle back off) were done in the morning before the scrap man arrived. Check the weather
forecast first though. Wasn't much fun in the rain ![](/images//smilies/sad.gif)
Baldrick
posted on 6/2/06 at 04:21 AM |
Your procedure is fine but once it's outside why jack the car up?. My mate and I just pushed the whole car up onto it's side
(you're not worried about the shell are you) and stripped everything out much easier that way (with an angle grinder mostly). Once finished you
can push it back over onto old pallets or something so the removers can get a strap unter if required. You can still cover it if it offends the
neighbors. My wife's face when she returned and found the car outside the house on it's side was priceless!
robertst
posted on 6/2/06 at 11:13 AM |
thank you all for your inputs, some are very amusing and imaginative, but i think it might be best to probably strip it in the garage and then weld
something on it to take it out of there... i'll post some pics so u get an idea of what i'm talking about..
cheers!
DaveFJ
posted on 6/2/06 at 01:22 PM |
you will be surprised how light it is when you have removed the engine/gearbox and all the rest of the running gear (drop the entire rear assembly). I
found I could lift either end on my own so the wife could slip a couple of old skateboards under the rear then I just lifted the front and wheeled out
onto the drive!
Dave
robertst
posted on 6/2/06 at 04:16 PM |
onto the drive!
u serious?? whoah that would make everything so much easier! then i wouldnt have to go through the hassle of taking it outside and stuff..
anyways here is a pic of my garage. my space is around 4 metres wide and 5 deep and is well away from the exit .
![](/galpreviews/) ![](/gallery/)
DaveFJ
posted on 6/2/06 at 04:38 PM |
is that a slope up to get out ? may prove a little harder..........
Dave
robertst
posted on 6/2/06 at 07:29 PM |
no, its horizontal.
