RazMan
posted on 14/2/06 at 09:42 AM |
Rewiring Sierra switches - which method?
Just interested how most people go about doing this. Do you ....
1. Cut & shut method - Join the cut ends of the old switch loom into new loom using butt splice connectors, solder joints or similar
2. Complete rewire method - Remove all old wiring and rewire plugs completely with new loom.
Raz
posted on 14/2/06 at 09:50 AM |
I soldered to the existing wires, then used heat-shrink tube over the top. Remember to make the joints at different distances from the switch,
otherwise you'll have a heap of sleeving in one place, which makes a big lump in your covering!
dave1888
posted on 14/2/06 at 11:03 AM |
Solder and heat shrink sleeving
mookaloid
posted on 14/2/06 at 11:09 AM |
As above
omega 24 v6
posted on 14/2/06 at 12:36 PM |
Heat shrink splices will allow you to see all the cable colours all the way through and are very effective.
