Author: Subject: Main Beam Flash
flak monkey
posted on 14/2/06 at 06:38 PM Reply With Quote
Main Beam Flash
Simple question:
Do you need to be able to flash main beam lights? Theres nothing in the SVA manual about it AFAIK, just wondering if its a requirement elsewhere (MOT?)
If there is no requirement then why is the feature fitted to all production cars?
Sera
http://www.motosera.com
mad4x4
posted on 14/2/06 at 06:49 PM Reply With Quote
I Think it is called a pass signal
The High way code state that you can flash you headlamps as a warning to on coming trafic.
Guess that this will be required.
Scot's do it better in Kilts.
Wadders
posted on 14/2/06 at 07:08 PM Reply With Quote
You dont need a momentary switch for sva or mot.
dave1888
posted on 14/2/06 at 08:02 PM Reply With Quote
IIRC you dont need it for SVA.
zxrlocost
posted on 14/2/06 at 08:51 PM Reply With Quote
Im going to make a nice bar that goes by my steering wheel that will have the r1 switch gear on this has a pass light also I can get everything working in harmony before I wire up my 350 thousand savage switches
mangogrooveworkshop
posted on 14/2/06 at 10:56 PM Reply With Quote
Originally posted by zxrlocost
I I wire up my 350 thousand savage switches
and relays
flak monkey
posted on 14/2/06 at 10:59 PM Reply With Quote
Yes, I have spent an hour or so wiring in a relay for my start button.
Thanks for the replies guys. Thats another redundant wire that can come out of my loom then.
Sera
