kev R1
posted on 22/2/06 at 08:14 PM |
r1 radiator and fan wiring
help wanted please!!
on my rad i have a black and a brown wire coming out of the temperature sender which is linked to a connector that comes out as green + brown this
then goes to the fan as it comes out of the fan you're left with 3 wires one green one brown and obvious earth.
from the R1 loom i have 1x brown and 1x blue wire marked up as rad switch.
how do i wire this up
i also have a green/red wire and a black/blue wire which according to the haynes is supposed to be wired to a temperature sender? i'm lost! any
help much apreciated,kev
smart51
| posted on 22/2/06 at 08:47 PM |
is yours an early R1 with a separate themerature sensor and thermostat switch or a later one with a combined sensor and switch?
kev R1
| posted on 22/2/06 at 09:28 PM |
i think it's a '99 there in the haynes manual the temp sender is nowhere near the rad switch, cheers,kev
Jasalarms
| posted on 23/2/06 at 12:39 AM |
Kev, i had that nissan micra rad modified with the R1 temp sender. should only be one connection to that.
When i tested the fan switch i found the extra wire could be used with a switch as a overide to bring the fan on in hot conditions.
Dont think i was goner use the R1 wiring for the fan switch, just rely on the micra one already wired to the fan.
But i could be wrong
