piddy
| posted on 14/3/06 at 11:06 PM |
Fog light switch
Hi.
Does the fog light switch have to have a symbol on it? For SVA or can one of these be used.
piddy
| posted on 14/3/06 at 11:07 PM |
Or one of these
flak monkey
| posted on 14/3/06 at 11:13 PM |
No symbol needed, just a tell tale light.
Sera
http://www.motosera.com
muzchap
| posted on 14/3/06 at 11:14 PM |
According to the manual - as long as there is sufficient notification to the driver then any switch is fine.
So if the switch lights up when the fog light is on - I'm assuming it will be fine.
If you can - for SVA - put a bit of card and write FOG LIGHT on it - then put some sellotape over it...
If it falls off on the way home from the passed SVA ---- oh dear :-(
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
emsfactory
| posted on 15/3/06 at 12:42 AM |
I did this! wrote on isulating tape with pen. On the first fail sheet I was asked to provide proper symbols. Bought a couple of sheets from a mail
order electrical place. Cant mind the name. Cost a quid for about 100 symbols and different words.
