johnjulie
posted on 17/3/06 at 09:36 PM |
SMITHS ELECTRONIC SENSOR SPEEDO???
Anyone used one? I want to fit a Smiths Magnolia 80mm gauge in my Caterham, and wondered if this is the easiest way to go, regarding callibration.
Cheers John
JFDI
"Just F*****G Do It"
muzchap
posted on 17/3/06 at 10:29 PM |
I have a Smiths Telemetrix - are they the same?
Mine is calibrated through 'jumper' settings on the dial and it registers electronic pulses from the magnetic senders on the
driveshaft.
Murray
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
johnjulie
posted on 19/3/06 at 07:00 PM |
Thanks for the reply, I Guess it will be the same. Did you have any problems setting it up? Where and how on the drive shaft did you fit the magnets
etc.
Cheers John
JFDI
