Chris_G
| posted on 21/3/06 at 10:40 AM |
Help with Alternator Connections ???
Anyone know what terminal is what on this Alternator. It's off a Suzuki Vitara.
Many thanks
Chris
Now finished! Xflow-Zetec swap with GSXR TB's and Megasquirt.
Chris_G
Another view just for general identification...
rusty
| posted on 21/3/06 at 12:02 PM |
It is denzo yes.
The big one is the main output.
The three connection on the plug are one for the dash light, one for the field exciter and one additional output.
Sorry I do not know which is which but could look some time this week.
The exciter wire needs to be live with the ignition on but not while cranking the engine. This may be a problem as alot of cars only have a combined
exciter and indicator light wire.
I'm not sure what the second output wire on the plug is for but I tested it through on my toyota loam and it connected to the main poer output
wire that connects on to the big bolt.
Chris_G
| posted on 21/3/06 at 12:11 PM |
Thanks Rusty but it's not a Denso, it's a Mitsubishi. Have a look
HERE towards the bottom, its the same as HTSP0975.
Anyone know which connector is which?
Chris
tigersupercat
| posted on 21/3/06 at 12:54 PM |
as viewed from the back....
turn alternator until plug is this way
__
top one is not used, left one is Ignition, and one on the right is the warning lamp.
and the studded terminal is the B+ (battery)
Kevin
Chris_G
| posted on 21/3/06 at 01:45 PM |
Thanks Kevin and welcome aboard!
I have seen that configuration on a Denso alternator HERE, is it coincidence that
its the same for a Mitsubushi one or is that where you got your information from? Don't want to appear to be doubting your wisdom but I would
like to have some level of confidence before connecting it up wrongly!
Thanks again,
Chris
tigersupercat
| posted on 21/3/06 at 02:32 PM |
Hi Chris,
I work for a Motor Factors, looked it up in the Lucas Catalogue!
Deckman001
| posted on 21/3/06 at 02:55 PM |
quote: Originally posted by tigersupercat
Hi Chris,
Cheat !!
Glad to have you aboard matey
Jason
Chris_G
| posted on 21/3/06 at 03:02 PM |
Hi Chris,
Thanks Kevin, looks like I'm sorted then
Chris
rusty
| posted on 21/3/06 at 03:22 PM |
I think that must be a standard Jap type conector as out unit is off a toyota.
Just a note about the ignition connection on our engine it is def only connected to the ing 2 ie not powered while cranking.
NS Dev
| posted on 21/3/06 at 03:36 PM |
surely ign 2 is on while cranking or the engine won't start as the coil is usually off ign 2?
RazMan
| posted on 21/3/06 at 04:38 PM |
A bit late I know but I'll post it anyway
Has anyone got a connector to fit this plug?
Raz
