Author: Subject: Double Pole/ Double Throw Ignition Switch
speed8
posted on 21/3/06 at 01:26 PM Reply With Quote
As the title. Anyone know where I can get one?
Basically just on/off positions but with two sets of wiring being switched with it.
posted on 21/3/06 at 01:35 PM Reply With Quote
Simple use a relay
rusty
posted on 21/3/06 at 03:26 PM Reply With Quote
Key Switch
but key is not the best
DarrenW
posted on 21/3/06 at 04:30 PM Reply With Quote
I got one that sounds just like you are after from Mac#1. i didnt use Sierra stalks etc and removed the steering lock. Fitted a basic on - off ignition switch instead and immobiliser as the security device.
speed8
posted on 25/3/06 at 04:26 AM Reply With Quote
Cheers guys, been away for a couple of days hence no reply.
I'll check with Mac#1 but everything seems to be on/off but only for a single circuit. If push comes to shove I can use a switch plus key.
Syd Bridge
posted on 25/3/06 at 03:32 PM Reply With Quote
Andy,
You're wanting a dpst switch. Double PoleSingle Throw.
RS No. 316-838, 15A £3.91
Rubber cover, no.233-3936 £0.54
There's a few more in the catalogue, but the one above would be more than ample.
Syd.
speed8
posted on 27/3/06 at 11:32 AM Reply With Quote
Syd
It's a keyed ignition switch I'm after.
2 position, On/Off but I have four wires. In the On position 1 - 2 connect and 3 - 4 connect, so I need 4 terminals. Is that DPDT or DPST, can never figure it out. The ones I find only have two terminals.
posted on 27/3/06 at 06:04 PM Reply With Quote
Normal way to do this is to use a relay operated from the ignition switch.
Switching the ignition switch to on supplies the ignition and also energise the relay which switches the other circuit -- quite simple.
Syd Bridge
posted on 27/3/06 at 07:15 PM Reply With Quote
Originally posted by speed8
Syd
You didn't say you wanted a KEY!
In that case, you want RS no. 182-556 £3.27
I've used some big mothers of switches in boats. Switch a handful of circuits and more, at once. There's one that you can build up yourself, just by adding extra modules to the back, but I can't find the info at present.
The relay will do the job, but if you can do the job with a single switch, then that's one less thing to go wrong...and usually at the worst possible time.
Syd.
speed8
posted on 28/3/06 at 02:42 PM Reply With Quote
Sorted now. Cheers lads.
