omega0684
posted on 22/3/06 at 11:00 PM |
fans
evening all, does anybody know a decent manufacturer of fans that are cheap, im looking for a 9 or 10 inch fan
Alex
muzchap
posted on 22/3/06 at 11:08 PM |
www.mac1motorsports.com
About £45 for a new 10"
I seem to be buying everything from him lately - Mark is a top bloke - can't recommend him enough
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
TheKingofBling
posted on 22/3/06 at 11:13 PM |
fans
car builder solutions do a 10" for £45 think this comes with all the quick mounts too.
omega0684
posted on 22/3/06 at 11:24 PM |
linky linkies boys
AlexS
posted on 22/3/06 at 11:26 PM |
quote: Originally posted by omega0684
linky linkies boys
Just off topic for a second - How do you???
muzchap
Lazy B'stard
CLICK ME LAZY OMEGA BOY
Remember MAC1 includes VAT - Car Builders is PLUS VAT.
makes a big difference on locost vs highcost
omega0684
posted on 22/3/06 at 11:37 PM |
car solutions one is £40 + VAT for fan and the £25 +VAT for thermostat + p&p, so that works out even more expensive than DAX
muzchap
posted on 22/3/06 at 11:41 PM |
What engine you using? Can't you re-use the thermostat off that?
omega0684
posted on 22/3/06 at 11:53 PM |
no dont have it, im using a different engine from the donar.
muzchap
posted on 23/3/06 at 12:02 AM |
Hmm - ok try Mac#1
OR fleabay usually turns up some fans for around 30-40 quid..
posted on 23/3/06 at 08:34 AM |
I would say try the local scrap yard; I have doen a fewrtimes ... but the smallest I have found tend to be 13 inch.
posted on 23/3/06 at 08:52 AM |
Are you going to any kit car shows in the near future? If so, can you wait that long?
The reason for asking is that fans seem to be one of those items that the traders heap up and compete over prices with each other.
I got a really good fan a couple of years ago for around £20.
RazMan
posted on 23/3/06 at 09:36 AM |
Raz's tip of the week:
Don't use the cable tie thingies that normally come supplied with new fans. They will eventually work loose and then vibrate themselves through
the rad core and leave you stranded at 2 am on a Sunday morning - trust me on this one
Make a proper bracket - a permanent solution.
Raz
DarrenW
posted on 23/3/06 at 10:48 AM |
i made brackets out of off cuts of floor chequer plate. They bolted to the fixing on the Micra rad and allowed the fan to be ositioned nicely in front
of the rad. I shaped the brackets so they didnt cause any obstruction.
Took some thinking about but work well.
I must admit that i found mounting the rad and fan to be one of the trickiest jobs. It was on 2nd attempt that i was happy with rad fixing. For bottom
mounts I used some thickish 1" wide flat bar, bent it into shape and fitted rubber mounts. Rad sat onto the rubber mounts at the bottom and was
held down with further straps at the top - again with rubber between rad and bracket. I just need to get them painted at some stage when i flush out
the cooling system.
O/T - im amazed by how dirty the coolant has got, even after flushing out before filling. i must try and see if i can get some coolant system flush to
try and clean it. This is my pre-blazing hot summer job!!! No rush then.
wicket
posted on 23/3/06 at 12:30 PM |
I've one of SVC budget fans, £30+p&p
http://www.s-v-c.co.uk/
Its fine.
