Author: Subject: engine loom
skint scotsman
posted on 24/3/06 at 02:34 PM Reply With Quote
engine loom
being a bit of a numpty at times i am yet again asking for help from the all knowing oracal that is locostbuilders....
.... looking for a nice simple idiot proof diagram of what is required for the engine side of a loom (i.e. what is needed to make the engine go broom broom)????
i've got the constant live and earth to starter and the trigger wire to the starter from ignition , just cant figure out the rest.
cheers in advance
told you i was a numpty engines a 2 ltr pinto on carbs
[Edited on 24/3/06 by skint scotsman]
DarrenW
posted on 24/3/06 at 02:41 PM Reply With Quote
electronic ignition or points dizzy?
skint scotsman
posted on 24/3/06 at 02:52 PM Reply With Quote
points dizzy
the simpler of the two i hope
rusty
posted on 24/3/06 at 03:35 PM Reply With Quote
power from ignition to +ve of coild then -ve of coil to the points.
That is for a 12v coil if you have the 9v coild system you require a resistor and relay.
skint scotsman
posted on 24/3/06 at 04:28 PM Reply With Quote
cheers all but kinda lookin for a schematic diagram
Chris_G
posted on 24/3/06 at 07:08 PM Reply With Quote
Try looking through the diagrams HERE.
Chris
Now finished! Xflow-Zetec swap with GSXR TB's and Megasquirt.
