piddy
| posted on 25/3/06 at 09:45 AM |
Edis 4
Hello all I'm at the wiring stage and was wondering, what wires are used from the EDIS when using a Mega Squirt?
I presume Live,Earth,SAW and PIP signal.
But what else?
A wiring diagram would be good.
Chris_G
| posted on 25/3/06 at 10:33 AM |
Here you go piddy....
Now finished! Xflow-Zetec swap with GSXR TB's and Megasquirt.
Chris_G
| posted on 25/3/06 at 10:35 AM |
Plenty of reading HERE too
Chris
piddy
| posted on 25/3/06 at 06:14 PM |
Thanks Chris.
Do you know wheere I can buy the connection plug to fit the coil pack?
Chris_G
| posted on 26/3/06 at 12:41 AM |
I got one by posting a wanted thread on this forum, otherwise the scrappies are probably the best bet.
Chris
piddy
| posted on 26/3/06 at 06:02 PM |
I've been told from a member of the Mega squirt forum that this diagram is incorrect! pin 10 should go to coilpack 1 and pin 12 to coilpack 3.
Anyone esle found this to be the case.
| posted on 27/3/06 at 03:36 PM |
It's not hugely important, if it is wrong it just means your HT leads would need to be swapped between the two coils.
