Author: Subject: Sierra Fuel Sender
whitestu
posted on 27/3/06 at 08:05 AM Reply With Quote
Sierra Fuel Sender
Hi
Has anyone used the standard Sierra fuel sender? If to how have you fastened and sealed it in the tank?
Stu
James
posted on 27/3/06 at 10:46 AM Reply With Quote
I cut out the hole from the top of the Sierra fuel tank (if you see what I mean! ) and used this as a template to draw around on the Locost tank.
I then chain drilled and filed until the Sierra sender fitted.
It sealed by using the Sierra sender gasket.
Take care when cutting the hole in the tank. The Sender is a twist fit so you want to cut a hole that means the sender ends up the right direction.
Hope that helps,
James
whitestu
posted on 27/3/06 at 01:18 PM Reply With Quote
Thanks James - very helpful.
I should have taken more notice when I took it out of the Sierra!
Stu
