chrsgrain
posted on 27/3/06 at 01:39 PM |
Relay question??
Hi all,
I need some help! I'm completely electrically illiterate!
I want to run both my fuel pump and headlights via relays from the little wires in the loom - which relays would I need for this? Any tips about
wiring them up would be great as well...
Chris
posted on 27/3/06 at 01:58 PM |
quote: Originally posted by chrsgrain
Hi all,
Chris
you need 3 relays; one for fuel pump, one for dipped beam and last one for full beam.
Use maplin 12V relay: N02AW; http://www.maplin.co.uk/Module.aspx?ModuleNo=37526&criteria=automotive%20relay&doy=27m3
wire up as below.
the item labelled "fan" would be your lamps or fuel piump. The item labelled "thermostat" would be an on/off switch.
Use fat wires to cay the current to the head lamps.
chrsgrain
posted on 27/3/06 at 02:25 PM |
Awesome!
The modern interpretation of back of an envelope....
Thank you!
Chris
