lsdweb
posted on 27/3/06 at 10:07 PM |
Sureseal Connectors
Hi Guys
Anybody used Sureseal connectors here with RS
I've never used them before and need to know how easy they are to use, in particular, how do you remove the pins when you got it wrong??!!
Crimping etc no problem.
Regards
Wyn
[Edited on 27/3/06 by lsdweb]
Wadders
posted on 27/3/06 at 10:54 PM |
Sit down, take a deep breath then look here
http://rswww.com/cgi-bin/bv/rswww/subRangeAction.do?catoid=-1600756356&cacheID=uknetscape
lsdweb
posted on 28/3/06 at 06:30 AM |
Thanks Wadders
I'd seen those prices but didn't know if the tools were essential (I was hoping to use my existing crimping tool).
Oh well - Vehicle Wiring here I come!
Nick Skidmore
posted on 28/3/06 at 07:43 AM |
I've tried to do sureseal without the tools and found it impossible.
The parts are so delicate that you wreck the pins etc. installing them.
A better bet are the soft rubber ones from Amphenol, in 2 to 6 pole, they do have tooling but I have used them a lot with a little wd40 and a thin
scriber to push the pins home.
They are about twice the size of a sureseal, but a sureseal is quite small.
They are also available from RS in the automotive connector section.
Syd Bridge
posted on 28/3/06 at 09:41 AM |
I use a few bayonet lock plugs/sockets, usually use the solder terminals though, with a piece of heatshrink over each joint, then put the whole thing
together.
Syd.
lsdweb
posted on 30/3/06 at 09:05 PM |
Thanks guys - much appreciated - I probably don't need waterproof connectors but will look at the other options.
wyn
