Dusty
posted on 1/4/06 at 07:16 PM |
Zetec/Omex
Wiring up the ECU. The Crank position sensor and starter solenoid wires start and run mostly along the same route. Obvious to tape them together but
will this lead to the CPS signal getting swamped with interference when cranking?
Difficult to separate them as the run is only about two feet, behind dash to L footwell end.
[Edited on 1/4/06 by Dusty]
paulf
posted on 1/4/06 at 08:40 PM |
The CPS wiring should be shielded , if so you shouldnt have a problem.
Paul.
Dusty
posted on 1/4/06 at 09:07 PM |
It is shielded so no problem then. I can happily wrap them together in loom tape.
