RazMan
posted on 10/4/06 at 09:57 PM |
Radio aerial?
In a fibreglass car it is probably not neccessary to have a conventional aerial connected to the head unit. What are the alternatives?
Raz
posted on 11/4/06 at 08:59 AM |
what about a small bee-sting type aerial mounted under the scuttle/bonnet?
ch1ll1
posted on 11/4/06 at 11:29 AM |
If your driving your car right, you wont be able to hear the radio !
and all that extra weight as well
RazMan
posted on 11/4/06 at 03:46 PM |
I was wondering if an aerial needs a ground plane to work properly. If not I could put a length of wire into the glass fibre away from any chassis
rails and connect to that.
Raz
posted on 11/4/06 at 05:46 PM |
Needs an earth. totest for a badly earth aerial touch it with your bare hands with the radio on, if the volume increases it has a bad earth
ady8077
posted on 11/4/06 at 07:32 PM |
Hi
I've fitted an aerial to my Stylus, fixed to the rear wing, no earthing required and i get very good reception, bought it from maplins
http://www.maplin.co.uk/module.aspx?TabID=1&criteria=Car%20Aerials&ModuleNo=30161&doy=11m4
Adrian
