zxrlocost
| posted on 21/4/06 at 08:58 AM |
handbrake warning light
Im just looking at the switch on my handbrake. its got the push in switch and a brass coloured strip which goes from one side with a screw over the
push in switch to the other side which has also got a little screw
thats it am I missing something because no matter what I do ie hold the wire on one of the screws push the switch in and out etc
my test light stays on
I didnt take the handbrake from the car so dont know how its originally connected
thanks chris
Peter M
| posted on 21/4/06 at 09:19 AM |
Does the light stay on with wire disconnected if it does then the brake fluid level may be low as it doubles up as h/brake ,low brake fluid light.
If it goes out when disconected from handbrake then the fault lies around h/brake switch.
zxrlocost
| posted on 21/4/06 at 09:20 AM |
no sorry mate Im just using a test bulb on the handbrake switch at the mo
havent got that far yet
Peter M
| posted on 21/4/06 at 09:40 AM |
Normally h/brake switches work on earthing the warning light.Wire goes to switch via terminal/screw the switch is then normally earthed via mounting
screw.So with h/brake on the switched is earthed to chassis,with h/brake off the switch should be open circuit.If light is on with h/brake on/off then
either the switch is faulty or you have wired the the switch wrong.Try with switch off the h/brake and see if with your test lamp if you can by
operating switch for the light to go on/off.
zxrlocost
| posted on 21/4/06 at 09:51 AM |
think the switch must be missing something as theres no break in the whole thing ie its a metal strip which goes round the switch and is held on by
the two screws
so wherever you touch theres its a permanent connection I think
ta chris
BKLOCO
| posted on 21/4/06 at 10:49 AM |
There should be a male spade connector above the brass strip that you are describing.
It sounds as if this has been broken off.
A common occurance.
New switch or a dashboard switch is the answer. Handbrake switch is not a requirement but it is used as the brake fluid warning lamp test switch which
is an SVA requirement.
a dash mounted switch will do as an alternative but the hand brake switches are available as a spare part.
zxrlocost
| posted on 21/4/06 at 10:56 AM |
I have the savage warning light its not a switch though
so dont i need the handbrake one to work for the sva
Dusty
| posted on 21/4/06 at 10:58 AM |
sierra switch pic. You need a method of testing the low fluid warning light from the driving seat. A 'handbrake' switch does this and is not
needed in its own right. You could use a dash mounted switch.
[Edited on 21/4/06 by Dusty]
zxrlocost
| posted on 21/4/06 at 11:03 AM |
great pic mate thanks mine is missing the spade connector part
ta chris
