Davros
posted on 3/5/06 at 03:58 PM |
Indicater Problem
Have a Robin Hood with the usual Sierra based electrics & now I have the problem of one side of the cars indicators are not flashing but the relay
is clicking wildly at about triple speed, then if you put the hazard warning on every bulb appears to be working & flashing normally. Can anyone
give me clue as I hate electrics!
Davros
posted on 3/5/06 at 04:14 PM |
Sorry Team
Searched a little further into the forum & found the nearly same problem that had been solved the only difference that my lights where originally
working!. Also sorry about my spelling & keep up the good workl
Brook_lands
posted on 3/5/06 at 04:18 PM |
Symptoms of the same problem, its clicking wildly because power is not going to the indicators bulbs.
I suspect the hazard switch is incorrectly wired.
You are in my neck of the woods, U2U me if you need more help.
posted on 3/5/06 at 06:27 PM |
Could be a faulty indicator switch. If the flasher relay is clicking power is going somewhere other than the bulbs.
