pajsh
| posted on 16/5/06 at 09:17 AM |
Heat Protective Covering
SVA man says my alternator leads are too close to my 4:1 so I need to cover the wires.
Can anyone suggest where I can get some heat protective sleeving.
I've seem some in Vehicle Wiring Products catalog but only good for upto 150 degrees C so not sure if he will be OK that.
I thought of lagging the downpipes instead but not sure if this will help enough and opinion seems divided as to whether it's worth it.
I used to be apathetic but now I just don't care.
muzchap
| posted on 16/5/06 at 09:25 AM |
Hi mate
I lagged my downpipes and built a heatshield. One of the members on here had some spare.
You can buy from RallyDesign/BurtonPower etc - quite expensive - or get some from another car in the scrapyard
  HeatShield on Alternator
~Yup this is an early photo - exhaust has more ties on now etc
[Edited on 16/5/06 by muzchap]
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
DarrenW
| posted on 16/5/06 at 11:05 AM |
Im sure you can get heat proof sleeving from RS etc. Not sure what protection it provides.
On my pinto install i routed the wires around the front and along carb side away from exhaust for this very same reason - this might be a locost
solution without needing to buy / wait for anything.
