locoboy
posted on 20/5/06 at 08:34 AM |
standard wiring colours
I need to extend my bike loom to fit my car.
If i went to the scrappies and cut out the longest section of a car loom i can find, am i likely to come across a selection of the same coloured wires
as i have in my bike loom, which i can then use to extend the bike loom and keep everything correctly colour coded?
If so this has to be a cheaper way than ordering a few meters of evey coloured wire i need to extend.
Locoboy
zxrlocost
posted on 20/5/06 at 08:39 AM |
have fun mate youll be luck if you can match the yam colours
I personally wouldnt bother
prewire to check all works ok then just use solid colours
its only the lights that really need extending
and there only simple wires
posted on 20/5/06 at 10:07 AM |
As he says - you've no chance matching colours bike to car so you may as well just splice in your extender wire of equivalent capacity.
posted on 20/5/06 at 12:45 PM |
I used some old Sierra loom I had in the shed, when you wrap the new wiring you only see the ends so it's still the bike colour. Volvo estates
are a good source of long wire runs.
