tks
posted on 22/5/06 at 07:39 PM |
Speed sensor
what do we use as a speed sensor?? glued on the prop??
Tks
graememk
posted on 22/5/06 at 07:56 PM |
magnets araldited to the uj from the gear box to the prop
donut
posted on 22/5/06 at 08:11 PM |
I tried araldited and i lost 2 magnets and the others were not where they were suposed to be!!
DarrenW
posted on 23/5/06 at 08:23 AM |
I fitted 2 magnets 180deg opposed onto the Diff prop adaptor - not onto the prop itself. The diff has less movement in it so keeps the distance
between magnets and sensor more stable.
Adhesive:
1. Used araldite at first (not the fast set stuff). OK for 1200 miles until i had g/box leak - transmission oil got onto araldite and seemed to soften
it. I lost one magnet.
2. Ive now glued the magnets firstly with Wurth 2 part superglue and then with JB Quikweld all around to supprt the magnet (also a very light smear
over the top.)
Forgot to say - before bonding the prop adaptor was filed to ensure i had a roughened bright surface and both this and the magnets were cleaned with
Wurth spray cleaner (very heavy duty stuff).
