Author: Subject: Angle of fog light & rear panel
jamesbond007ltk
posted on 24/5/06 at 11:36 AM Reply With Quote
Anyone know how far from vertical we can get away with with respect to the foglight? Mine is 22 degrees off vertical as shown in my quick sketch below.
[Edited on 24/5/06 by jamesbond007ltk] Rescued attachment Fog angle.jpg
posted on 24/5/06 at 11:37 AM Reply With Quote
It has to be vertical - they check it with a big L-shaped gauge.
ReMan
posted on 24/5/06 at 11:38 AM Reply With Quote
None!
it has to be vertical (for SVA)
DarrenW
It has to be vertical so i guess 1 or 2 deg tolerance max. You wont get away with your pic.
i mounted mine from a bracket that is fastened to the chassis. Later i can move to wherever i want.
Others have fabricated a bracket behind so they can mount in same position as you are indicating.
ditchlewis
posted on 24/5/06 at 11:49 AM Reply With Quote
i bought a light support from tiger, this was for a traditional rear light setup. cut the centre out of it, bonded the 2 parts back together and painted it.
looks neet and purpose made, and all for a tenner. also sva proof
ditch
zxrlocost
posted on 24/5/06 at 12:09 PM Reply With Quote
svc sell a angled light holder take a look in my archive and see if you can make it out its the the fog one is the same as the others just the other way around
ta chris
richardR1
posted on 24/5/06 at 05:36 PM Reply With Quote
I used the s-v-c carbon light mountings and I would say that my fog light is probably 10 degrees off the vertical mounted on my Indy rear panel. Passed SVA at Beverley at this but I suppose it depends on the tester/station.
MK Owners Club Member 1015
