Krismc
posted on 27/5/06 at 08:42 AM |
Voltage supplys! Neuros and bullet cam
Was wanting to buy/make some volatage supplys for my neuros and bullet cam does anyone know what the supply to the neuros should be, mine isnt marked
up??
And the camera i guess is 12v
[Edited on 27/5/06 by Krismc]
flak monkey
posted on 27/5/06 at 08:49 AM |
Camera is 12V. And AFAIK the neuros is 9V. Have a look on the power supply for it, it should tell you what the output voltage is.
Theres several threads about it on the neuros forum.
http://www.neurosaudio.com/community/forum/topic.asp?TOPIC_ID=6377
Sera
http://www.motosera.com
Krismc
posted on 27/5/06 at 09:00 AM |
Cheers but the power supply doesnt have anything written on it and when i measure with my meter i get 4.4v that cant be right??
You know what is the cheapest/and best card to use with the neuros as well??
Krismc
posted on 27/5/06 at 09:04 AM |
1) On the packaging on the supply is down as 9-13v
2) the neuros have 5vDC written on it
3) and i measure the output as 4.4V
although the forum reccomends 9V
...and it says when charging- although it doesnt have a internal battery!
flak monkey
posted on 27/5/06 at 09:28 AM |
Some of the neuros alternatives also run on 5V. I would try a 5V supply and see if it works. If not try 9V.
Could always email Neuros and ask them if you dont want to risk it.
The pro duo cards are the best to use as they support up to 2Gb of storage. The large cards are expensive though!
Take your pick off ebay:
http://search.ebay.co.uk/search/search.dll?from=R40&satitle=pro+duo
The sandisk and sony ones are probably the ones to go for.
Sera
wilkingj
posted on 27/5/06 at 10:16 AM |
I intend to make a 5V supply and a 9v suply.
It will run from 12v off the car, and will use a 7805 and a 7809 chisp which will regulate to thoses voltages at a Max of 1 Amp each supply which will
be more than enough.
You will need a few extra resistors and capacitors around each chip to complete.
Fix the lot in a slly box. and ensure you have enough ally to use as a heat sink. it put one chip each end of the box to separate them heat wise.
Its fairly simple to do.
Best Regards
Geoff
http://www.v8viento.co.uk
