Author: Subject: Rev counter with megajolt
Danozeman
posted on 27/5/06 at 10:19 AM Reply With Quote
hi chaps. iv got a sierra cluster temporarilly,(maybe permanent). iv got everything working except thd rev counter.
i connected it up to pin 11 on edis but nowt. Should it work?
Dan
rayward
posted on 27/5/06 at 11:13 AM Reply With Quote
have you tried connecting it to the tacho out from the megajolt?
also some oe tachos need a couple of diodes in circuit to make them work.(diagrams on Megajolt site)
Ray
Surrey Dave
posted on 27/5/06 at 12:22 PM Reply With Quote
The only way mine would work was with 2 diodes and a resistor ,wired into each side of the coil loom /plug, I think Paulf had some component values.
Danozeman
posted on 27/5/06 at 07:15 PM Reply With Quote
Ill have look at this resister thingy. Hopefully i can get it to work. My plan is to hack the cluster about and make into summit nicer.
Dan
paulf
posted on 30/5/06 at 08:43 PM Reply With Quote
Hi Dan
The diagram is on the CD I supplied with the unit, it uses 2 in4004 diodes and a 15v zener diode to give a signal from the coil pack leads.
I used it to drive an escort tacho and it worked fine, it would be worth trying the megajolt tacho output first as that may work with the ford tacho.
Let me know if you need any more info
paul.
Danozeman
posted on 31/5/06 at 10:04 PM Reply With Quote
Cheers lads. I tried the tacho output off the MJ and it still didnt work.
Fitted the 3 diodes and it works a treat now. Left me skint though!!! 24p!!!!!!!!
Dan
