Author: Subject: speed to sender
piddy
posted on 29/5/06 at 07:18 PM Reply With Quote
speed to sender
Hi.
I'm using Telemetrix Gauges.
The sender has two wires from it both Blue. (so iguess it doesn't matter which is which)
The wiring instructions for the wires from the speedo are as follows:
Green- Switched ignition (easy)
Brown/slate-Connect to harness reset switch or not used (not using)
Red-pull up/down (?)
Red/White-Illumination (easy)
Black-earth(easy)
White/Black- Speed signal input (hall ecu) (?)
Red/Blue- Speed signal input for low output senders (?)
Light green/Purple-Not used (not used)
I guess I connect one of the wires from the sender to Red/Blue.
But which one should the other connect to?
tom_loughlin
posted on 29/5/06 at 08:56 PM Reply With Quote
I used the red/blue to one of the wires on the speedo sender, and depending on the sender, the other wire to either a live, or an earth - whatever makes the reed click in the switch- if you listen to the switch when passing over a magnet, youll hear a clicking sound.
Hope to help
Tom
redeye
posted on 29/5/06 at 09:12 PM Reply With Quote
this link should help you linky
sounds like you have the reed sensore, in which case you should connect the blue wire from the sensor to the black and blue on the speedo
only jus connected mine up today.....jacked the car up and had the speedo up to 70.....eeeeeek
piddy
posted on 30/5/06 at 10:39 AM Reply With Quote
The link suppied by REDEYE states the following.
The electrical connections to the sensor should be made as follows:-
One wire should be connected to a switched positive supply, i.e. power should be off to the sensor when the ignition is off.
The second wire should be connected to the black and white wire on the harness supplied with the speedometer.
The CAI sensor can easily be tested for quality of signal, without the aid of special meters by connecting one wire to a positive supply and the other wire to a 12v bulb, which has an earth/ground connection. The bulb should illuminate if the sensor is working properly.
redeye
posted on 30/5/06 at 09:04 PM Reply With Quote
sorry i meant to say black and white not black and blue....doh
