marcotuinenburg
posted on 31/5/06 at 02:42 PM |
Sierra starter to fireblade loom ?
I hope someone can help me with this thing. I'm trying to connect the wires coming from the backside of the thing where you put the starting key
that came from a Ford Sierra with the fireblade loom, but i can't find out what colour has to go where ?
There are a yellow (contact1), black/yellow (contact2), black/blue (start) and red cable.
The red one was the easy one but what are the colours of the cables coming from the fireblade loom that i have to connect.
I tried to find out with the Haynes manual but couldn't sort it out.
Please Help ..........
I'm using a SC33E fireblade from 1999.
Thanks,
Marco
tks
posted on 31/5/06 at 03:06 PM |
mhh not very complicated do you have a wireing diagram of that bike?
i can help you.
also make a sheme what the starter does.
for example if you power the red one where does that power go to at wich position..
Tks
Kev99
posted on 31/5/06 at 03:29 PM |
I used this on my 893cc engine should give a good idea if not the same
http://www.dodgyroger.com/locost/Tech_Tips_Wiring_the_Fireblade_engine.pdf
[Edited on 31/5/06 by Kev99]
