Author: Subject: LEDs for sidelights?
tegwin
posted on 2/7/06 at 10:21 PM Reply With Quote
I am thinking about fitting white LEDs behind my sealed beam units to act as sidelights....has anyone done this before?
Is it SVA legal?
Dunc
RazMan
posted on 2/7/06 at 10:30 PM Reply With Quote
No reason why you shouldn't use leds as long as they are bright enough (most are not) I've used leds for every light on the car except headlights. At one stage during testing I had all the lights lit up with one PP3 battery!
I have a feeling you will have to drill your reflector to insert them into a non-sidelight headlamp - that might be tricky but feasible.
Raz
tegwin
posted on 2/7/06 at 10:36 PM Reply With Quote
I have sealed beam units with a small window at the back designed to take some kind of sidelight bulb I assume....
Will have to look for some super bright ones...
RazMan
posted on 2/7/06 at 10:42 PM Reply With Quote
The main problem with leds is the narrow angle of the beam - try to find ones with diffused lenses as they will probably suit your application. You can probably glue them to the back of the 'window' as they will probably out-live the car
Check out this eBay seller for some good deals
[Edited on 2-7-06 by RazMan]
Raz
Chippy
posted on 2/7/06 at 11:45 PM Reply With Quote
Maplins carry an extensive range of LED's, worth giving them a look, if you have a store near you. Alternatively you could get there catalogue. atb Chippy
mcerd1
posted on 3/7/06 at 07:17 AM Reply With Quote
Try here: www.ultraleds.co.uk
