bigandy
posted on 7/7/06 at 10:55 PM |
Battery thingy, any ideas what it is for?
Evening folks. I bought a couple of batteries today, one for my kit, and the other for the tintop (S reg corsa).
One of them had the fitting shownin the pic on it, and I'm not sure what it is for. It looks like it some kind of fitting to accepta hose, so
would it be to meaure the pressure in the battery? or maybe keep it topped up automatically or something?
Any ideas anyone?
Dammit! Too many decisions....
RazMan
posted on 7/7/06 at 10:58 PM |
Breather?
Raz
ruskino80
posted on 7/7/06 at 10:59 PM |
factory fill point or pressure breather?????????????????
stevec
posted on 7/7/06 at 11:04 PM |
Breather/ Vent.
russbost
posted on 7/7/06 at 11:20 PM |
It is indeed a vent, without which the casing could explode!!!
bigandy
posted on 7/7/06 at 11:22 PM |
If it is a breather, it seems strange that it is fitted externally like that though. I would have though that any sort of vent/pressure relief
arrangement would be located somewhere less likely to be knocked off...
snapper
posted on 7/7/06 at 11:23 PM |
By product of a charge in electrolight is oxygen and hydrogen, best put a pipe on it and vent it away from sparks.
mark chandler
posted on 7/7/06 at 11:49 PM |
Its the breather for a boot mounted battery, ie where the battery is within the car as opposed to under the bonnet.
In these instances you have tube that vents to open air that you plug on.
Regards Mark
bigandy
posted on 8/7/06 at 12:19 AM |
Aaah, that makes a bit more sense...
AS the battery is going to be mounted under the bonnet, I guess it is okay to leave as is then?
ANdy
zetec7
posted on 8/7/06 at 08:28 AM |
attach a hose to it, and run the other edd away from the engine compartment, and away from exhaust/sparks. You haven't lived until
you've had a battery expolde on you from poor routing on the breather. I was riding along on an old motorcycle, when BANG - felt like I'd
been kicked in the butt by a mule, battery acid all over the bike and me, etc. Use the breather, lad!
