mad4x4
posted on 10/7/06 at 03:26 PM |
VDO Speedo Wanders
I have a vdo speedo and hall effect (cable pickup)
When doing the speed test it wanders b ans much as 25%
Any ideas?
Scot's do it better in Kilts.
posted on 10/7/06 at 03:34 PM |
Have you bolted the speedo in yet?
Sounds like the thing a cheap/old speedo would do... is it reading the correct nominal speed?
Agriv8
posted on 10/7/06 at 03:59 PM |
what pulses per mile have you enetered ?
Regards
agriv8
snapper
posted on 10/7/06 at 04:38 PM |
Use a shielded cable and earth the shielding. Only a very small current so you can use TV aerial coax.
bimbleuk
posted on 10/7/06 at 05:47 PM |
If its like a Smiths gauge then it could be down to the sensor tolerance. I'm reading the bolt heads on the diff flange and the instructions
(Smiths) say less than 2mm is required!!
As above maybe try to get a cleaner signal or check the earthing.
[Edited on 11/7/06 by bimbleuk]
