davrus
| posted on 14/7/06 at 08:25 PM |
relays
Me again , can anybody tell me if i need a seperate relay for the indicators and hazzards or if they run on the same one , does anyone have a wiring
diagram for how they go , many thanks
Davrus
mark chandler
| posted on 14/7/06 at 09:31 PM |
Same relay/clicky box, then a twin gang switch required for hazards. Sorry no diagram but in basic you terms switch to earth via the bulb, either left
or right with the stalk. The hazard switch merely connects both when thrown.
You wire it by taking a feed from the relay to both poles on the supply side to the hazard switch then output connects to each indicator circuit in
turn.
Regards Mark
MartinDB
| posted on 14/7/06 at 10:16 PM |
I don't know what switches you're using, but this is how my Durite rockers are wired.
  repeaters
The hazard switch supplies an ignition switched 12v to the relay when it's off so the indicators only work with the ignition on. When the
ignition's off, the hazard switch when turned on supplies a permanant 12v to the relay.
Martin.
