The Doc
| posted on 15/7/06 at 10:52 AM |
Rear Lights
Is it OK to place rear lights strait onto wing or do we need a 'wedge' to bring them up perfectly vertical.
Anyone suggest some good budget units?
cct7kitcars
| posted on 15/7/06 at 10:59 AM |
i put our light flush to the rear wheel arch and dont have a problem at sva
but be warned the fog light has to be vertical to the ground
joe
iank
| posted on 15/7/06 at 11:22 AM |
Only the fog light needs to be perfectly vertical.
Mounting on the wing is not a problem (for SVA anyway, check clearance depending on the style of light)
Budget units are available from the usual suspects.
Best to buy from a show (Harrogate 12-13 Aug if you are close) so you can get a feel for the quality and avoid the postage.
Try:
http://www.s-v-c.co.uk/
http://www.vehicle-wiring-products.co.uk/
http://www.premierwiring.co.uk/
and of course
http://www.ebay.co.uk
kev R1
| posted on 15/7/06 at 12:51 PM |
i can do you a full set same as fitted to the back of mine with reflectors(without vertical plynth) but plain black plastic ones for £55!!!
