Avoneer
posted on 19/7/06 at 09:46 AM |
Seedo Magnets Dimple Orientation
Dimple against the meal or facing out into air?
Pat...
posted on 19/7/06 at 09:57 AM |
If you're using ETB magnets then the dimple definitely faces out (towards the air).
Stick em on tight mind!
Krismc
posted on 19/7/06 at 11:05 AM |
yea dimple out with MY ETB guages
donut
posted on 19/7/06 at 01:33 PM |
same here
Avoneer
posted on 19/7/06 at 10:52 PM |
Cheers.
So inverted niples facing out it is!
After trying all sorts on the Avon, I think there is only one solution to fixing them on:
Blob of Sikaflex and then gaffa tape.
Tried glassing them on, araldite and a few other methods and they all failed on the Avon.
Gaffa tape on it's own was the only thing that eventually worked.
Don't think the Sika will ever let go though, but the gaffa on top should do the job.
Pat...
Krismc
posted on 20/7/06 at 08:26 AM |
i used arildite and seems to work fine
numnuts
posted on 20/7/06 at 11:45 AM |
Hi guys Ithink this may be incorrect as the instuction from my digi dash states :: The dimples must face the propshaft and not outwards .. not sure if
correct but thats what my instruction states !!. hope this helps
Avoneer
posted on 20/7/06 at 10:58 PM |
I couldn't find that in the instructions - where does it say that?
Not questioning you, just curious as want to get it right.
Pat...
Avoneer
posted on 20/7/06 at 11:31 PM |
Found it on the website:
"The magnets have small dots on one face. These denote the magnet North pole. The magnet
MUST be mounted with the dot facing down."
Pat...
[Edited on 20/7/06 by Avoneer]
numnuts
posted on 22/7/06 at 04:21 PM |
I am now sure as my speedo passed sva yeaterday perfectly at 30 50 and 70
Krismc
posted on 23/7/06 at 09:36 AM |
well mine works and im sure thats the way i put them!?! might me different for different applications
DarrenW
posted on 24/7/06 at 03:43 PM |
Dimple in on mine. Araldite was also crap. Softened after a while and magnet detached itself. i then fixed with Wurth superglue after getting down to
bright metal and using Wurth high power cleaner. Then used JB weld for extra stiction. Been Ok since.
