Dick Axtell
posted on 22/7/06 at 10:49 AM |
Wooden Dash Panel
Hi All -
Have made my own dash from 16mm ply. Will shortly be fitting instruments (if the upholstering goes OK!).
Will a separate, common earth cable be necessary, for the instruments? Using Premier Wiring loom.
How did other users of wood dashes achieve satisfactory earth circuit?
TIA
Dick
[Edited on 22/7/06 by Dick Axtell]
John Bonnett
posted on 22/7/06 at 11:29 AM |
I have always run a separate earth from each component and joined to a common earth that is also grounded to the chassis. Many electrical problems are
a result of bad earthing so it is as well to be as careful with that as with the power inputs. that also goes for cable rating.
The great thing about a wooden dash is that it can be sanded and polished if you decide against covering it with leathercloth.
John
