Author: Subject: Anti- theft device query.?
GeoffB
posted on 24/7/06 at 09:31 PM Reply With Quote
I have no normal ignition switch..
Im using a flick up switch and button to start
I also have a three postion switch where you can take the key out in two postion ie.. switch postion to run and remove the key
switch too not run and remove the key
i know i need an anti-theft device as well as a nomal ignition switch
I dont suppose they will allow the flick up and push button as a Normal ignition switch..Or do they
If not can i fit a basic fia type switch (just the one connector type)
to the main flick up switch feed, therefore not allowing power to the flick up switch.??
hope that makes sense
muzchap
posted on 24/7/06 at 09:55 PM Reply With Quote
I used a battery isolater from Merlin Motorsport.
Its a battery terminal with a green twisty wheel - you put it on the negative terminal - that should count as at least one form of immobilisation.
They're about £7 + postage - have you got a steering lock ? That should count as the second...?
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
phoenix70
posted on 24/7/06 at 10:48 PM Reply With Quote
I take it you won't be keeping the steering lock, as that is an anti-theft device. I passed the SVA with just a normal ignition key and a steering lock.
