Author: Subject: headlamp wiring Vicki Green loom.
Danozeman
posted on 24/7/06 at 09:37 PM Reply With Quote
Evening all.
Does anyone who has a Vicki green loom know what wires out of the bunch for the switches are for the headlamp switch??
I havent got wipers so dont need them and im not usig the sierra light switch.
Thanks in advance.
Dan
posted on 25/7/06 at 10:48 AM Reply With Quote
u2u me to remind me and I'll have a look tomorrow and let you know.
Nick
Danozeman
posted on 25/7/06 at 05:36 PM Reply With Quote
Okey doke thanks mate....
Dan
posted on 30/7/06 at 02:42 PM Reply With Quote
Hi Dan,
Looking at my wiring diagrams + wiring, I think this is right...(bear in ind I'm using Sierra stalks)
Side lights (+tail lights) switch input is fed by a permanent live (purple) then the output connects to the side lights (red) via a fuse (10A).
For the headlights, you need to use a relay. Take a fused (20A) feed from the battery, switched by the relay to the head lights (blue/red). Either use a permenent live (purple) or use the output from the side light switch (red) (2nd option means head lights will only work on when side lights are switched on) to feed the relay coil input and then switch the output of the relay coil to earth with your head light switch.
For the main beam lights (blue/white), repeat wthe headlight set-up with another fuse and relay. There should also be a main beam (blue/white) output in the bunble of wires feeding the instument panel - this is used for the main beam tell-tale lamp on your dash board.
I hope this makes sense, not easy to expalin in words - a diagram would probably make more sense.
Let me know if you get stuck and I'll try sketching it out for you.
Nick
[Edited on 30/7/06 by nick205]
