Author: Subject: lights relays
davrus
posted on 26/7/06 at 10:30 PM Reply With Quote
lights relays
hi ya , got indicator and hazzhards sorted now , just dip beam and main beam to sort out . do i need 2 seperate relays , or just one , running on a normal rocker switch for side and head lamps , i have a sierra stalk for main beam , if any one has wiring diagram would be great
Many thanks
Getting there slowly
Davrus
DIY Si
posted on 26/7/06 at 10:32 PM Reply With Quote
Side lights probably don't need a relay. They only draw 1.65 A. Assuming 5 watts a corner. Dip beam is up to you and depends mostly upon the switch you use. I would suggest a relay for the main beam though.
RazMan
posted on 27/7/06 at 07:59 AM Reply With Quote
Probably best to run two relays as it is better for the dip switch.
Raz
posted on 27/7/06 at 10:51 AM Reply With Quote
defo better to have one for main/dip, and if you are feeling flush and want some redundancy, one for each bulb so that if a relay blows, you sill have ther other lamp working .
maplins sell the relays, less than £ 2.
NS Dev
posted on 8/8/06 at 07:41 AM Reply With Quote
just use a 5 leg changeover relay, no need for two relays.
