Author: Subject: Fusebox
speed8
posted on 31/8/06 at 05:13 PM Reply With Quote
Fusebox
I know there has been a few threads on this but I can't find a link to a specific product.
Is there a fusebox that will allow you to use one input feed for multiple outputs using a busbar type arrangement.
Or just a simple busbar holder type of thing to split the feed.
I don't want to use crimping and soldering multiple wires from one.
i.e. one input from 12V perm, outputs to hazards, horn, sidelights.
posted on 31/8/06 at 05:20 PM Reply With Quote
a very good question that, to which i eagerly wait the answer! Its a messy affair having to loop wires from one to the next.
stevebubs
posted on 31/8/06 at 06:00 PM Reply With Quote
VWP Link
Scroll down to the modular fuse and relay housing system. "Mini-blade fuses can either be fed individually or adjacent fuses linked by busbar"
[Edited on 31/8/06 by stevebubs]
speed8
posted on 31/8/06 at 06:29 PM Reply With Quote
Originally posted by stevebubs
VWP Link
I looked at that but it seems to be an expensive solution to a simple problem by the time you buy the housing then the different modules.
speed8
posted on 31/8/06 at 06:30 PM Reply With Quote
Originally posted by CaLviNx
Hi
premier wiring does one like you want, in differing sizes.
I'll call them in the morning and see what they have. The website doesn't show it or else I'm looking in the wrong place.
lsdweb
posted on 31/8/06 at 07:02 PM Reply With Quote
I used a normal fuse box and fed it with a multistranded battery lead. I then split the strands of the battery lead into groups, heat shrunk it all up and connected these to the individual terminals - it tooka bit of time but it was cheap and effective!
Regards
Wyn
iank
posted on 31/8/06 at 09:46 PM Reply With Quote
This thread shows some volvo's have them - if scrabbling round scrapyards is ok
http://www.locostbuilders.co.uk/viewthread.php?tid=40022&page=2
posted on 1/9/06 at 04:15 PM Reply With Quote
______________________________________
Hmmm.. the thread has nothing on it....
iank
posted on 1/9/06 at 06:51 PM Reply With Quote
Not sure what's going on then
This a picture of the volvo item
http://www.locostbuilders.co.uk/viewthread.php?action=attachment&tid=40022&pid=333271
