Author: Subject: Large Savage starter switch wiring question
chockymonster
posted on 5/9/06 at 01:05 PM Reply With Quote
I'm looking at getting one of the large pushbutton savage starter switches but have a question first.
The pics of it I've seen show 6 connectors at the back.
I'm guessing that this has a relay built in.
Does anyone know if it can be used as a simple push to make as my start circuit needs to join 2 low current wires to start the engine.
Howlor
posted on 5/9/06 at 01:08 PM Reply With Quote
Fairly certain it can if it's like mine.
esn163
posted on 5/9/06 at 02:02 PM Reply With Quote
Hi, thats how ours is wired, I don't believe it is a relay but a double switch instead where it can be used to switch two seperate circuits at one time keeping them both seperate. If you look carefully on the side IIRC there is a diagram labeling the pins 123 123 one set for each side.
Again IIRC you just need to use one side ie 1 set of 123 and connect your two wires to 1 and 2. If that doesn't work its the other way around ie 1 and 3.
HTH
Ed
[Edited on 5/9/06 by esn163]
Indy Build Photos
** Build pages **
Photo Bucket Pics
shortie
posted on 5/9/06 at 09:28 PM Reply With Quote
This might help, shows how I wired mine, pins 1 & 2, illumination on + & -
http://www.dewweb.co.uk/indyblade/images/Indyblade_wiring_v17.pdf
HTH,
Rich.
