piddy
| posted on 11/9/06 at 06:30 PM |
Led lights
I'm using these lights fro SVC.
Are the carbon affect surround different depths?
I was under the impression that I only needed to drill three small holes to mount the LED ones but they protrude out the back of the surrounds unless
I've got the wrong surrounds.
asn163
| posted on 11/9/06 at 07:01 PM |
Hi, No you have the correct surrounds. We used these and we had the same problem. We cut out a cresent shape in the rear arches to accommodate the
bottom edge of the LED light unit.
Simon
piddy
| posted on 11/9/06 at 07:40 PM |
Ok Thanks.
Just a bit more to do then.
Steve @ sVc
| posted on 12/9/06 at 04:09 PM |
Piddy - the LEDs do not need a hole if they are in the twin housings, but we kept the single ones as shallow as poss. We may be able to get some that
are deeper - interested??
Regards
Steve @ sVc
piddy
| posted on 18/9/06 at 10:12 PM |
Steve @SVC.
Thanks for your reply,but I've fitted them now.
