Author: Subject: points dizzy coil plugs
jabbahutt
posted on 18/9/06 at 06:12 PM Reply With Quote
Hi
anyone know where i can get hold of some new rubber plugs for connection to the low tension studs on a coil?
I already have one on the lead from the distributor but I'd like to replace the eyelet connector on the vicki green loom to connect the poistive side
I take it I'm right that it's one of the white/white black wires that connects to the coil
thanks
Michael
posted on 18/9/06 at 08:07 PM Reply With Quote
When i was running a 1300 Cross Flow in my Escort, prior to getting another one for the Kit, the low tension leads were connected with crimped female bullet connectors.
Dusty
posted on 18/9/06 at 09:43 PM Reply With Quote
You should find the studs have a thread. Just use a eyeletted male spade on the LT terminals held on with a suitable nut.
White to pos terminal, black/white to negative (goes off to rev counter so you still need to add a connection from neg terminal to dizzy.
posted on 21/9/06 at 09:05 AM Reply With Quote
as ^^^ said; there usually is a square u-shaped bit of metal with a hole that fits over the stud with two 4.7 mm male spade terminals; exactly like this:
that will et you back all of 15 p (I have made one from copper tube, slit it and cut/file to shape)
you can either use a ring terminal crimped onto the wire or female spade terminal with the connector shown above.
