The Doc
posted on 18/9/06 at 08:13 PM |
Escort Stalks on a Sierra Column
Can it be done?
Fozzie
posted on 18/9/06 at 09:40 PM |
quote: Originally posted by The Doc
Can it be done?
Oh yes !!!!!!!!
......but with a modicum of ingenuity and quite a bit of hair pulling.
But worth it......IMHO.
Fozzie
posted on 18/9/06 at 10:31 PM |
Which Escort?
Mk3 on may be a straight swap.
Fozzie
posted on 18/9/06 at 10:40 PM |
Pete, mine was a MK2......
Fozzie
The Doc
posted on 19/9/06 at 05:21 AM |
It's really to try and avoid the use of relays, as the sierra switching aint man enough without.
Fozzie
posted on 19/9/06 at 08:17 AM |
Yes exactly that! I did use the loom from my donor MK2 for the entire car. I shortened the stalks a tad for neatness, and re-assigned the stalks to
varying functions, hence doing away with the need for switches on the dash. The stalks of the MK2 being ally, soooo much nicer than the flimsy Sierra
ones anyway......IMO of course!
HTH Fozzie
Schrodinger
posted on 19/9/06 at 03:41 PM |
What wiring loom are you using? as the switches are imaterial if the wiring isn't up to the job
The Doc
posted on 19/9/06 at 04:44 PM |
Escort Loom
Schrodinger
posted on 19/9/06 at 05:13 PM |
If the Escort loom dosn't have any relays then you should be ok but if there are any in there ie for the lights then you should keep them as the
wires between the switch and the relay may not be up to the current you will be asking them to carry.
