Tiger Super Six
posted on 2/10/06 at 12:52 PM |
Haynes Manual Help??
Guys,
I have an electronic speedo for a type 9 box and need to know which wire is which.
I have three wires: -
Yellow
Black
Brown
I think that they are there for: -
12v+
Earth
Signal
But don't know which is which and don't want to guess. Is there anyway of telling or does anyone have a Haynes manual that says????
Mark
Tiger Avon
mookaloid
posted on 2/10/06 at 12:56 PM |
this was only recently discussed on here - try a search perhaps?
Mark
RazMan
posted on 2/10/06 at 01:06 PM |
Ford colour trends would suggest:
Black - earth
brown - +ve
yellow = signal
Easy to check though - just connect a 9v battery (very low current so you won't melt anything) across the power leads and a multimeter on the
signal (other meter wire to earth) Spin the shaft and see if you get pulsing from the signal.
Raz
Tiger Super Six
posted on 2/10/06 at 01:12 PM |
The earlier posts on this were from me - i.e. whether it could be used (which is a yes) - this is my next problem.
Razman - Thanks for idea of testing it, one quick question though, if you got the + and - the wrong way round with a battery how would you know.
Sorry, dumb on electrics!!
Mark.
[Edited on 2/10/06 by Tiger Super Six]
Mark
Tiger Avon
RazMan
posted on 2/10/06 at 03:12 PM |
Erm .... it won't work The reason for using the 9v battery (PP3 or similar) is that you won't damage the sensor if you connect the
wrong way round as it will not supply more than a few mA. Just connect it for long enough to try it out.
Raz
Tiger Super Six
posted on 2/10/06 at 05:13 PM |
I see - my thought was like a light bulb it doesn't matter which side goes to the earth/live, it will work either way.
Guess that's not the case so thanks and will try it tonight.
Mark.
Mark
Tiger Avon
Dusty
posted on 2/10/06 at 09:51 PM |
Surely
Brown = earth
Black = ign live
Yellow = signal
Tiger Super Six
posted on 2/10/06 at 10:38 PM |
quote: Originally posted by Dusty
Surely
Brown = earth
Black = ign live
Yellow = signal
Yes, tested it tonight and that's the result. I was sure of yellow as the signal but had been unsure of the live/earth.
Mark
Tiger Avon
posted on 2/10/06 at 11:01 PM |
Brown is always earth in Ford Sierra looms and black is an ignition switched live anywhere in the loom so that only left the yellow for you to figure
out.
RazMan
posted on 2/10/06 at 11:17 PM |
oooops
Raz
