Author: Subject: Electrical SVA requirements BEC
Boost69
posted on 5/10/06 at 05:26 PM Reply With Quote
Just been thinking. I'm giong to use the wiring loom from the bike. What else would I have to add to the bike wiring to pass the SVA? Hazzards, fog and reverse, anything else?
Boost.
rayward
posted on 5/10/06 at 05:29 PM Reply With Quote
handbrake/brake level warning light
fesycresy
posted on 5/10/06 at 06:06 PM Reply With Quote
Not for the SVA, but I put in a fan over ride switch, just so I could cool the motor down after a run.
posted on 6/10/06 at 06:52 AM Reply With Quote
reverse lamp is not required. but if fitted, then it is tested - put the wiring in and then fit the lamp later.
posted on 6/10/06 at 09:38 AM Reply With Quote
Handbrake light isn't a requirement either, just the test function.
