Author: Subject: Flexible corrugated rubber tube?
RazMan
posted on 8/10/06 at 04:43 PM Reply With Quote
I need to run some electrics to my doors and need some smallish 'concertina' rubber tube to go between the body and door.
Any ideas guys?
Raz
DIY Si
posted on 8/10/06 at 04:47 PM Reply With Quote
Can you get small bore water pipe in the size you need? Or would this be too thick/stiff?
Sun Tzu, The Art of War
RazMan
posted on 8/10/06 at 04:59 PM Reply With Quote
Too stiff for this job I'm afraid. I found some ultra flexible stuff at one of the shows last year but at 25mm diameter it is way too big - I only need to run 3 wires inside.
Raz
DIY Si
posted on 8/10/06 at 05:10 PM Reply With Quote
Do you already have the wires in place, or could you get some 3 core wire that has another outer layer of insulation and use that?
StevieB
posted on 8/10/06 at 05:13 PM Reply With Quote
Have you looked through the site for Woolies? They might have something workable.
RazMan
posted on 8/10/06 at 05:18 PM Reply With Quote
I have already got the wires in place. I could use some blow moulded tube as an outer covering but I am sure it will kink when it bends through 90 degrees.
Woolies was the first place I looked
[Edited on 8-10-06 by RazMan]
Raz
DIY Si
posted on 8/10/06 at 05:22 PM Reply With Quote
How much movement do you need for this? Is there any particular ends you need for the attachment points you have?
jacko
posted on 8/10/06 at 05:27 PM Reply With Quote
How long do you need the tube ? on the v-h corsa there is a pipe that may do you from body to hatch back about 5in long
Jacko
Scrapyard time.
Most cars with leccy windows have them but I've never seen them for sale aftermarket. They usually have a grommet type end.
RazMan
Ideally they need to be about 100mm long, 10-15mm diameter with a grommet type end so I can pop it into a hole in the bodywork. The door moves through 90 degrees (scissor action) but it is fairly tight space so will kink if not corrugated.
Raz
RazMan
posted on 8/10/06 at 05:28 PM Reply With Quote
You might be right there Pete.
Raz
Humbug
posted on 8/10/06 at 05:40 PM Reply With Quote
Try almost any car at the scrappy. You just need to open a few doors/tailgates to see if there are any suitable. I used some of various sizes from an old Metro to cover track rods, etc.
russbost
posted on 8/10/06 at 06:57 PM Reply With Quote
Second the above it's a trip to your "local recycling centre!"
RazMan
posted on 8/10/06 at 08:02 PM Reply With Quote
Yep, that's where I will be tomorrow
Raz
