Chippy
posted on 8/10/06 at 10:54 PM |
Ford engine management wiring diagram, and pin tables
Hi All, does anybody happen to have a copy of the EEC IV wiring diagram, and the pin tables, for a 1989 Ford 2.9i V6. I have finaly located a way of
fitting a MS system, but need to get hold of the above info, to be able to do it. I have two (differing) copies of the Haynes manual for the car, but
niether shows it. Thanks in advance. Regards Ray.
[Edited on 8-10-06 by Chippy]
Dusty
posted on 9/10/06 at 01:52 AM |
Blue Haynes for sierra shows EEC 1V wiring diags 13-64 and 13-65 for CVH and DOHC. Both show the pin out numbers of the EEC 1V and where they go if
you have a lot of patience and a good magnifying glass. I would expect the pin functions are common. Sorry but no clues to the 2.9i engine.
zzr1100rick
posted on 9/10/06 at 07:31 AM |
Hi i have a pin data book what is the engine code ie BRC BRD/E/F so as to get the correct pin data
Chippy
posted on 9/10/06 at 10:06 PM |
ZZR1100RICK
Hi, its the BRC engine, pre cat, but set up for unleaded. Any chance you could email me the pin no's. Thanks Ray.
